Noisy injectors what to do
Old May 26, 2001 | 08:29 PM
El Guapo's Avatar
We just bought a 94 Regal w/ the 3.8 TPI. There is an RPM dependant ticking that occurs while accelerating.
I know this is definitely not 3rd gen, but since there is no Regal board handy, I figured Id see if you guys will help a chap out.
I think that its my injectors. It is a ticking that increases w/ RPM and is only heard while accelerating, at cruise, normally it is quiet. And it is in almost ALL accelerating, not just WOT.
My questions:
1) How would I test the theory out? In neutral there is no noise, in D w/ parking brake on, there is no noise either.
2) If it is my injectors, what does it mean? Am I on my way to replacing them, are they on their way out,etc?
3) What can I do about it?
Thanks guys
Clayton
Old May 26, 2001 | 11:46 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
I know my '87 305 injectors tick!
Old May 27, 2001 | 01:25 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Mine tick like heck at idle sometimes. I think it's normal. I gotta open element setup, so all I hear under throttle is sucking noise. I checked the ohm level on mine about 2 wks ago and they're fine.
I also got a 95 Monte w/ the 3100 sequential fire intake. They tick too.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited May 26, 2001).]
Old May 27, 2001 | 01:58 AM
Vader's Avatar
El Guapo,
If you are certain it's the injectors clicking, go to sleep without a worry - that's O.K. I have had some injectors that can be heard with the hood closed at a low idle and have driven them for 170,000 miles without a problem. I swear I can still hear the LT1 injectors at a low hot idle, and Rich tells me they are like new for flow, spray, and leakage. They only have 110,000 miles on them so the jury's still out.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 27, 2001 | 07:47 AM
El Guapo's Avatar
Guess I just got spoiled when I had the 2.8 Firebird. Never heard an injector. Oh well. Thanks for the reassurance.
Clayton
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
dimented24x7
Sep 6, 2015 03:51 PM
