Need help picking the right cam...
Old Oct 30, 2004 | 10:02 PM
onebadassbird's Avatar
Car: 91' Trans Am
I am currently building a 355cid motor and was wondering which cam do you guys think I would be best off running. Before I go ahead and ask let me give you some info about what I have.
The heads are cast #376450 with larger ports and valves (1.94/1.625). 60cc chambers with dished pistons so I will have about 10:1 compression. For the intake I have SLP runners and siameased plenum with edlebrock baseplate. I have 3.73's in the back and will match the stall to whatever cam I get. Lastly I have a pair of SLP Tri-Y Headers.
I am looking for something that could maby pull to 5,500 or so and I am not to worried about how streetable it is cause it wont be a daily driver. I need a hydrualic flat tappet cam. So far is sent a form into crane and this is what they told me to use with a 2,500 stall.
http://www.cranecams.com/index.php?...802&lvl=2&prt=5
also was looking at this one from TPIS
http://www.tpis.com/Catalog_sub_TOC...afts/Valvetrain
Any recomendations or info would be greatly appreaciated, thanks alot
Old Oct 31, 2004 | 08:04 AM
Vader's Avatar
Send the same details to Comp Cams, or call their toll-free help line. With their recommendation, compare and average the grinds suggested by all three. That should be a good starting point.
Old Oct 31, 2004 | 08:19 AM
Car: 91' Trans Am
Yea I actually have the comp cams paper already filled out, as I was going to compare them. I didnt think about averaging them tho, thanks
Old Oct 31, 2004 | 08:34 AM
ljnowell's Avatar
Do yourself a favor though, when you call comp cams. Over a 2-3 day period, call twice a day. Then take a look at what they recommended every time. I have seen people call 3 times and get 3 different recommendations.
Old Oct 31, 2004 | 08:44 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Crane PowerMax 278
Old Oct 31, 2004 | 09:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd suggest looking at the Comp 304 and 305 cams; then have a custom cam ground using the Xtreme flat-tappet lobes, that's as similar as you can conveniently get to whichever of those you think would be more appropriate (probably the 304 with those relatively poor-flowing heads). That would come out to something like a 5441 intake lobe and a 5212 exhast lobe, on 114° lobe separation, with 1.6 rockers. You'd get better results with 1.45" OD valve springs such as the 986.
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
92projectcamaro
Sep 29, 2015 07:07 PM
