When Should I Shift???
Car: 99 Formula
Axle/Gears: 342
I have a manual valve body, and considering my motor's torque peaks at 3500 rpm and the hp peaks at 5000 rpm, at what rpm's should I be shifting.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
Soon to be installed B&M Megashifter
and Exhaust Cut-Out
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
5000 or when you feel the engine stop pulling and making power.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I'd say shift just slightly before the motor tops out so that you don't lose time with it sitting on the flat spot at maximum rpm.
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say about 5200 to 5500 depending on the engine. some will peak and fall off right away, but some will still hold decent hp away's after the peak.
Ive heard 4250-4500 is really good if you're trying to accellerate really fast in an F-body
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
- Aiwa CDC-MP3 head unit
- Rockford Fosgate 360a2 amp
- pair of 12" MTX Thunder 5000s in a custom box
- Pioneer 3-way 6x9s, soon to add more more more!
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You can find out what rpm to shift at by looking at the tach after it shifts. It's recommended that your rpm point should be 500 rpm lower than peak torque after all shifts. Same with a TC. Stall should be 500 rpm below peak torque. The shifting is hard to do with a 700-r4 just cause of the big ratio diff between 1st and 2nd. 3.06 down to 1.63. That is what I've read on Summit's website.
darwinprice
17
Oct 11, 2015 11:51 PM
