TPI to carb
Old May 25, 2001 | 01:38 PM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
TPI to carb
what do i need to buy and do to go from TPI to carb? It's a 350 TPI, 700r4....thanks!
Wally
Old May 28, 2001 | 04:30 AM
IROCU69's Avatar
Car: 85 Sport Coupe Camaro
Engine: 1969 Camaro 350
Transmission: TH350
Axle/Gears: 3.73 Posi
Hey if your going from TPI to carb would you be willing to sell me the TPI setup?
And as for the TPI to carb deal heres what you need....
good intake manifold
apropriate cfm sized carb
HEI distributor
another issue is the fuel pump. I just cut mine out and replaced it with a bend 3/8 line with a fuel sock on the end. Then I bought a carter mechanical fuel pump and bolted it up to the blcok and ran the fuel lines to it.
If you have any other questions feel free to email me I can go into more detail as I've done this quite a few times. IROCU26@hotmail.com
-Mike
[This message has been edited by IROCU69 (edited May 28, 2001).]
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
