No Spark, May Be Distributor.
Old Nov 3, 2004 | 01:44 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
No too far back, my car one mourning wouldn't start. Come to find out there was absolutely no spark, well after taking the distributor cap and rotor out everything looked okay. advance auto parts tested the ignition module a few times it worked great. put the distributor back to get. the car started and ran like it was literally brand new. this mourning the same problem occured. what could be the problem?
Old Nov 3, 2004 | 01:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Coil, or pick-up coil, or poor power wire connection.
Old Nov 3, 2004 | 03:00 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Or low battery, the HEI needs atleast a full 12 volts to it. Try cleaning all the connections that go to the coil and cap. How many miles are on the cap and rotor? They also could be dirty or tracking due to buildup.
Old Nov 8, 2004 | 12:17 PM
Engine: 5.0L 305 H
The same thing happened today. Could it be the pick up coil?
Old Nov 8, 2004 | 01:30 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
So after taking the cap off and then putting it back on it works? Is the cap cracked at all? When you removed it is there any signs of moisture in/on the cap? Just to be on the safe side I'd replace the cap and rotor. Now the other thing that I'm thinking is that it's not the cap/rotor and it's the ignition module. After putting the cap back on it runs. Is the connectors from the module to the coil in good shape? That could also be your problem there. Just some food for thought.
Old Nov 10, 2004 | 09:20 AM
Engine: 5.0L 305 H
The rotor was replaced recently and it already has charred marks on it. What's causing this? Could it have something to do with the problem?
Fanatic1074
Oct 3, 2022 05:57 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
