wont start
Old May 28, 2001 | 03:45 AM
horhay89's Avatar
wont start
alright-
my 89 automatic rs is having some difficulty lately. about 20% of the time, she doesnt start, feels like the battery is dead. but the battery is fine, its been tested along with the alternator. has anybody had this problem or know what the deal with it is? jump starting it does work. any responses would be great. thanks a lot.
horhay
Old May 28, 2001 | 11:07 AM
ede's Avatar
ede
sounds like a bad connection, power or ground.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 28, 2001 | 11:04 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I just had the same problem. I checked everything I could think of, starter, battery, solenoid, battery cables. I had some wear in the ignition switch and after I replaced it the car started right up. My vatts system was working properly, but the key cylinder itself was worn.
The problem was an occasional thing until last week when it would not start at all. The car would jump start before it died completely, but you didn't have to let the battery charge at all just touch the cables to the battery and it would start.
I would check my connections and get the starter checked out. I was getting power to everything in the battery cables, but the car would not respond at all with the key in the start position.
The key cylinder cost about $40.00. You will have to get a key made which is about $20.00. You will also have to have a tool to remove the steering wheel and another tool to remove part of the steering column.
You don't have an airbag, so it won't be as big of a pain to change.
Check everything else first, but this was one of my last resorts before I ran out of ideas. I almost thought I would have to let someone else work on my car. If you need some info drop me an email.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
