Is the 1.6 exhaust valve too big for LB9?
Old May 29, 2001 | 06:49 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I will be cleaning up my stock heads and will be installing larger valves.
1. Will I be able to fit 1.6 valve in the 305 head?
2. What areas of the heads I have to mainly concentrate on?
3. I have a swirl type head. What would happen if I would move the swrirl ridge over a bit or even get rid of it?
Any other tricks to improve flow?
Thanks.
PS. I have decided to stick with my old heads.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
db057
Aug 22, 2015 08:17 PM
happyhapka
Aug 15, 2015 04:42 PM
