**** Killer??
Car: 1986 Iroc z z28
Engine: 305 tpi
**** Killer??
Im sure u all have heard stuff close to this before but I am desprete to know what do I need to kill these little bumble bee civics and other ricers?
I have a stock 1986 Irocz z28 with the 305 tpi and 700r4 trans
I am planning on building me a motor this summer but I havent decided on the right one yet.
what size motor should I build??
should I do a t56 swap
what gear ratio and etc
how much HP do I need to beat the average *****?
sorry for the noobness
Car: '86 Berlinetta
well, you really should be able to kill a 4 banger pretty easily stock. Try a tune-up first heh. Some things that you may want to do though, are things that you can use when you switch to the new block. new rear gears, full exhaust, ignition (though the stock one is good to streetable powers I believe?), if you're going to keep FI then get a LT1 intake (cuz it can be swapped over).
You should get a 350 short block since they're about a dime a dozen in junkyards lol.
If you have an automatic right now then doing a T56 swap will be a little harder, but not impossible or even "THAT" hard.. if you know how to drive a stick, and have the money to do it, go for it.
Rear gears I'd probably get 3.73s if you want it to be daily driven probably?
No problem with being a noob. Something every noob should know about is the "search" function. Needless to say, your questions aren't new.
Start off with a search. You are going to find all kinds of info about engine buildups, etc., etc. You might want to check out some of the 383 buildups.
Now the only question is: How much do you want to spend?
Back in the good old days, the statement was: you can't beat cubic inches.
These days, you can't beat cubic money.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The bigger the engine, the more power it will make. Start by upgrading the exhaust and adding headers. This will wake up the motor now, and won't choke the new engine.
Engine: 305 tpi
on thing I dont want is nitrous
and I dont watn to overdo it and twist my frame s my doors want close
I want to build a motor no body else really has some odd size or some thing
83 Crossfire TA
Sep 18, 2015 12:01 PM
Magman
Sep 12, 2015 10:43 PM
