Car wont crank
Old May 29, 2001 | 08:53 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Car wont crank
When I go to start my car it won't even crank. Then if I wait about 30 minutes and try again it will. Could this be a fuse, or a bad wire?
1992 L03
Old May 29, 2001 | 11:52 AM
sleeper's Avatar
Listen carefully for a click (under the car) when you turn the key. If there's no click then there's a wiring problem. If you hear a click but the starter doesn't turn then you have a bad starter solenoid (common with headers).
Reborn756
Sep 4, 2015 03:42 AM
TheExaminer
Aug 26, 2015 04:59 PM
Thirim
Aug 13, 2015 03:09 PM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
