A/C belt problem?
Old Nov 5, 2004 | 06:57 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
A/C belt problem?
Today i went outside to fire up the iroc and all of a sudden when I fire it up the belt started making a squealing noise and the a/c pulley sounded like it was grinding. So i took the belt off and tried to turn the a/c pulley with my hand and it is stuck it won't turn at all it is so bad to the point now that when i start my car the belt will start to smoke on the a/c because of all of the friction there i was thinking about taking out the a/c and put the a/c delete pully on but I want to keep my a/c has this happened to anyone other than me because i have never heard of a problem like this????
Old Nov 6, 2004 | 10:01 AM
Vader's Avatar
Was the A/C or defroster turned on during this episode?
Old Nov 6, 2004 | 01:43 PM
Ant's Avatar
Ant
no, I never really used the a/c I always use the 260.
Old Nov 6, 2004 | 08:44 PM
Vader's Avatar
There's a good chance that the clutch bearings are locked/toast. If the damage is severe, the bearing failure may have also damaged the hub shaft and is preventing the compressor shaft itself from turning. That's why you cannot turn it by hand, even slowly.
1992 Trans Am
May 10, 2023 07:19 PM
zayne0
Aug 24, 2015 07:22 PM
BikeFarm
Aug 11, 2015 11:35 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
