Blow fan stays on when car is off
Old May 28, 2001 | 09:43 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I shut my car off today and the fan blower didn't stop, I had to go under the hood and pull the wire for it. Any ideas what it could be? I don't want to have to keep pulling and replacing the wire everytime I shut the car off.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.32@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake, ported heads.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box, gutted cat.
Old May 28, 2001 | 09:45 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
On some cars it will stay on until your car cools down. Or it could be your temp sensor or fan relay.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
Old May 28, 2001 | 09:46 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
the fan relay on the firewall has took a ****. it needs to be replaced. tap on it a couple of times and if it aint to shot, then it will cut off.
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out....
www.formula350.com
or click below to email me
webmaster@formula350.com
Old May 28, 2001 | 09:48 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
No, I only ran it a minute, the engine didn't even pass 100 degrees.
I think your right about the relay. Can you tell me exactly where it is located?
1986 CAMARO Z28 -&gt;
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.32@ 106.4MPH 3300lbs less driver and speakers Next mods-&gt; Extreme Energy 268 cam, Holley street dom intake, ported heads.
1987 TRANS AM -&gt;
Old May 29, 2001 | 01:41 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
its on the drivers side firewall next to the flip-up light relay box. Just take a look. How do you get it to turn off without draining the battery?
www.formula350.com
Old May 29, 2001 | 03:09 AM
88CRUZIN's Avatar
had the same problem when i had the 2.8 in it. i cut the relay off and ran a wire from the fan straight to the fuse box. this worked out fine for me when i had the electric fan. hope this helps
88CRUZIN
Old May 29, 2001 | 09:20 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Guys I'm talking about the blower for the a/c and heater not the engine fan. The wire for it is on the passenger side firewall.
1987 TRANS AM -&gt;
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
novaderrik
Aug 10, 2015 12:44 PM
