miss firing
Old Nov 7, 2004 | 09:41 PM
bland_cd's Avatar
Car: 89 camaro iroc
Engine: 5.7
Transmission: 700
miss firing
The car misses when driving at steady state or under slight
loads, seems to be backfiring thru the exhaust. put the ignition
in by-pass, and the thing runs great, got all new igniton parts
but nothing seem to help. Its got the steady 9-10 volts from the knock sensor control mod to the ecm, grounds are all good, it also
has new injectors, any help with this HEI system?
Old Nov 8, 2004 | 12:50 AM
sellmanb's Avatar
Car: '86 Berlinetta
checked your timing?
Old Nov 8, 2004 | 01:18 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: miss firing
What do you mean..." Put the ignition in by-pass?
Old Nov 8, 2004 | 05:27 AM
bland_cd's Avatar
Car: 89 camaro iroc
Engine: 5.7
Transmission: 700
the base timing is set to 6 dbtc, just like the book says. runs
great with the tan/blk wire off, just as if you where setting the timing.
KCG
Jun 24, 2020 04:33 AM
PurelyPMD
May 5, 2016 04:57 PM
L98GTA87
Oct 19, 2015 10:43 PM
BLK87Z
Sep 18, 2015 11:29 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
