Check Out These Emissions Readings!!!
Old May 30, 2001 | 07:11 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Hydrocarbons = 832ppm
state standard 220 ppm
Carbon Monoxide = 7.62 pct
state 1.20 pct
Carbon Dioxide I actually passed 6.87 pct
What can I do to pass emissions, I ran my car for about 1 hour before testing except this time I didn't put in any alcohol on 1/4 tank gas, actually got slightly lower readings last time by doing this method but didn't help much.
Also I don't have a converter. Is there any way around this.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
Soon to be installed B&M Megashifter
and Exhaust Cut-Out
Old May 30, 2001 | 08:17 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Lean the *** out of your carb and back down the timing, and if you're bored add some alcohol to the tank too...you need all the help you can get right now...
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
