Can someone check my math. 3.48 w/ 5.850
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
We're boring the block to 4.040" because of skirt to wall damage.
Was thinking of running a SRP-139629 piston, which is for a 3.75" stroke crank. http://www.flatlanderracing.com/srpsbclowcomp.html
Run a 5.850" H beam rod, with a 3.480" stroke steel crank. The compression distance on the piston is 1.425".
I think that will work, and would make a 9.1:1 compression ratio motor.
Can someone check my math?
-- Joe
-- Joe
Car: 4
Engine: 6
Transmission: 5
That will put the piston surface at 9.015" from the crank centerline..... in a zero-decked block, .015" out of the hole.
Only you can determine whether that will work in your specific block.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Without buying these pistons and rods, how can I measure the block deck height from crank centerline? LIke what tool specifically?
I measured the installed height of my old pistons. At TDC, with a 3.480 stroke cast crank, 5.7" ibeam rod, and compression distance of 1.563", the piston was .025" in the hole. So I'm sorta guessing the block is fairly stock height.
-- Joe
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
Originally posted by anesthes
What is the formula you used for this? I was figuring dead even on a 9" block, so I made a math mistake .. ?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by rustybluebird
3.48/2+5.85+1.425=9.015
What piston would you use for a 6" rod (if I decide to go that route) ?
-- Joe
Car: 87 Firebird
Competition Products has lots of flattops and domes(hyper+forged) for a 3.48"/6" rod combo. I didn't see any dished or more than -4cc for releifs. I'm just assuming that you wanted a dished piston looking at the link in the first post is for a -16cc dish.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by Stekman
Thicker head gaskets or larger cylinder head chambers.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by Air_Adam
This CPW is with Stek... if you only need a little more clearance, get a thicker head gasket if that will do the trick. Getting different heads just because of this seems like a pretty drastic change to me though.
Think I'll go with the SRP 383 piston and the 5.850 rod. My deck is tall enough, infact, i'd take about .010 out so the pistons about .005 in the hole. Should work perrrrrfect.
-- Joe
