tons of white smoke!!
Old May 29, 2001 | 11:59 AM
83Z28's Avatar
I've got a TON of white smoke pouring out the back. It's cool to blast pedestrians with, but it can't be good for the motor. Also, the oil pressure is low. Is this a head gasket? Or something else?
Thanks for the help,
Derf
Old May 29, 2001 | 12:07 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
Head gasket
Old May 29, 2001 | 01:23 PM
Polecat's Avatar
white smoke is a bad sign....check your water level...I bet it's low.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Holley 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old May 30, 2001 | 01:11 AM
robbob's Avatar
It is your head gasket most likely.
Old May 30, 2001 | 07:16 PM
poncho9789's Avatar
If not the head gasket it's a cracked block.
On ether, the engine would get hot anyways,park the car quick.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
3.8TransAM
Oct 1, 2015 07:47 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
