CLUTCH & ADJUSTMENT!!!!!
Old May 30, 2001 | 08:46 PM
matty350TPI's Avatar
Ok i have been noticing that my clutch is only engaging near the end of the pedal stroke. It doesn't slip. I have tested for that by putting it in 3rd and flooring it at a low speed to see if it would slip, NO SLIP. Well how can I adjust this so that the clutch makes contact earlier in the clutch pedal travel.
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old May 31, 2001 | 01:18 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
How old is your Centerforce? and which model did you get?
I have the Dual Friction Centerforce and when I first had it installed the clutch would grab right when the pedal leaves the floor.
It's been in there for about 6 months and now it grabs a little higher than when it was new.
My friend put a Performance Ram Kevlar clutch in his 96 T/A and that clutch works the same as yours, grabs when the pedal is almost all the way up. Felt kinda strange for me when I was driving his car the other day, I'd either almost stall the car or burn the clutch, but that sucker has one helluva grip.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
