Passenger side dipstick with Stock exhaust manifolds?
Old May 30, 2001 | 07:06 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
hey all,
I posted this in the engine swap forum but haven't got any response yet, so I figured I'd see if anyone could answer here in the higher-traffic tech forum.
Help me out here. I'm planning on putting a mild 350 into my '83 soon. I've got an older 4 bolt 350 core to rebuild. It's got the dipstick on the other side. I'm planning on running the stock manifolds (until I figure out more which car I'm going to use for what--long story). I keep seeing say that "you'll have to run headers". Surely there's a simpler solution than that. I wanna go for the factory stock look (besides the fact that the stick will be on the wrong side ). Has anyone overcome this with a particular dipstick/tube from another application? I don't wanna hafta go with a streetrod dipstick, but that'll be more factory looking than headers I guess .
thanks
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
[This message has been edited by clemsparks (edited May 30, 2001).]
Old May 30, 2001 | 07:47 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
the oil pans interchange, use your old one
Old May 30, 2001 | 07:48 PM
Engine: 305TPI
if i were you I'd go with a windage tray, if possible...
might as well do it while the motor is apart, it's not much more to go that route
Old May 30, 2001 | 08:23 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I'm not worried about the oilpan. I'm worried about using the passenger side dipstick with stock lg4 exhaust manifolds. I don't think that my lg4 ('83) oil pan will interchange with my earlier model 350 block since the dipsticks are on opposite sides...maybe though, I'm not sure..not my point anyway .
anybody know about using a stock type dipstick (whether stock to an f-body or something else) will be possible?
thanks
Clem
Old May 30, 2001 | 08:46 PM
Engine: 305TPI
are you worried about using the AIR tubes?
if not, you should be able to get some older 305/350 exhaust manifolds that would do the trick for you, don't ask me what years, though
Old May 30, 2001 | 10:03 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
yeah, I'm planning on keeping all the smog and computer stuff intact. I'm trying to go for low hassle, factory look but with a little added umph.
I'm sure I can find something to work, I was just hoping someone else had already come up with a solution for this one .
thanks
Clem
Old May 30, 2001 | 10:30 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
You have two choices 1 buy a driver side exaust off of an older V8 and tap the new holes for the air tubes and then go to a muffler shop to modify your exaust. or get headers. I have gone through this before but I didn't have the choice of direct bot on headers. I had to buy headers and then go to a muffler shop to have a new Y pipe made.
Old May 30, 2001 | 11:09 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The R.H. and L.H. dipsticks require the matching pans for the application. (you can't mix them)
As far as using a stock L.H. dipstick with the stock manifolds that are for a R.H. motor, it doesn't work.
I bought a kit that I machined and installed into the block on a 400 so that the dipstick was re-located to the pass. side. It was a one off piece we had laying around the machine shop, I don't know if they are still available.
As far as an easy fix, I don't know of one. (except buying headers)
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited May 30, 2001).]
Old May 31, 2001 | 01:36 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Thanks guys,
I looked at the two engines tonight and you're all right...It won't work.
I've got a solution though! I'll fab up a sight tube on the oil pan of the 350 so I won't need a dipstick. Seriously, it shouldn't be that big of a deal
thanks
Clem
transaero
Aug 31, 2015 01:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
timonator
Aug 11, 2015 09:56 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
