"V" Belt Question
Old May 29, 2001 | 05:56 AM
custman87T/A's Avatar
"V" Belt Question
I finally put in my new condensor for the A/C,new o-rings,flushed system, added oil,pulled a vac. no leaks...and charged with the last of my R12. The system runs great except for the fact that I am going through belts. The belts seem to be turning into a black powder that is getting all over my engine then after about 2 hours it gets thin and snaps. I thought I might have a pulley with a chip in it so I replaced the dampner pulley and water pump pulley and checked the a/c pulley,but I still have the problem.Well 3 belts later and lots of cursing and I am no closer to solving the problem. I have no problem with the power steering belt or alt.belt just the a/c. Any help would be appreciated. Oh yea its an 87T/A 305 TPI with v-belts
Old May 30, 2001 | 07:08 PM
Someone has to have an idea on what it could be...I have worked on this for a week now and gone through 5 belts...thanks
Old May 30, 2001 | 07:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like your compressor may be bad...
Does it make any noise? If you turn the engine off, key on, and A/C on, what does it feel like turning it by hand?
ICON Motorsports
Old May 31, 2001 | 06:49 AM
Yes the compressor turns pretty easily by hand with the clutch engaged. What is going on now after I replaced the pulleys is that the belt "squeels" like crazy, I tighten the A/C to where it doesn't squeel under load then the alt. belt starts squeeling badly. I really am at a loss with this. It sucks that I have put over $200 into redoing the A/C and $50 in belts I can't get it to work properly.
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
