will a double 1.25 core, griffin radiator fit Ok in a 89 camaro
Old May 29, 2001 | 07:41 PM
AustinT's Avatar
Will the universal Griffin radiator that summit sells for 281 fit in my 89 camaro OK. Summit told me it was a direct replacement but I wanted to hear from some of you before I orderd it.
Old May 29, 2001 | 08:11 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
It's not a direct replacement. Mods to make it fit include:
A new upper support because the original isn't think enough to fit around the core.
Since the fans mount to the support, spacers or another way to mount them will be needed.
If you have a small 3/4" heater hose running to your radiator the griffin doesn't have provisions for it.
It doesn't have an automatic trans cooler.
The rubber stops in the bottom of the support need to be removed and cut for the hood to shut. Possible radiator to hood/airbox clearence problems solved by tipping the radiator back toward the motor.
It could fit, but it's not a 'drop in'
Here's a pic of my custom install. I fabbed up t-6 brakets for the fans/maf sensor and mount.
Old May 29, 2001 | 08:14 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
I bought a griffin radiator and it did not fit perfectly.it was a 19x31. The shroud wouldn't fit over it.I had too make a bracket for it and get an electric fan.
Old May 30, 2001 | 11:21 PM
AustinT's Avatar
Thanks Guys,
I think Im going to go for it
JoelOl75, is that the 1.25 or 1 inch core. Nice Job
Old May 31, 2001 | 06:54 AM
JoelOl75's Avatar
It's the dual 1" core.
Cools too good now, I don't have an air deflector and I have to get the 160 thermo out of it.
With the stocker it ran up into the 230's 235's in summer heat with the air deflecter mounted and the 160 thermo. Too hot IMO.
Terrell351
Jun 13, 2021 01:13 PM
I'llrocya
Feb 2, 2016 11:43 PM
Omega
Oct 1, 2015 02:20 PM
lakeffect2
Aug 23, 2015 08:44 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
