fuels pump
Old Nov 11, 2004 | 04:25 PM
red85berlinetta's Avatar
fuels pump
hey guys quick question about my fuel pump, i bought a new 80 GPH fuel pump and installed it a while ago. and i plugged of the fuel return line because it wasnt on the new pump. now is this bad at all and is it hurting my gas milage at all. thanks
Old Nov 11, 2004 | 05:49 PM
ljnowell's Avatar
A mechanical pump? What PSI does the pump put out? If there is no return line on a mechanical pump, well it doesnt need one then.
Old Nov 13, 2004 | 12:30 AM
well i understand if it aint on the pump then the pump dont need it lol what im saying is there a certain thing in the tank or by any chance it needs the return line... also to your other question i have no idea as i have it regulated to 5.5 psi
Old Nov 13, 2004 | 02:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
If it's not FI and doesn't have some exotic/wierd/overkill pump you don't need the return line. Was your car originally a TBI car by chance?
Old Nov 13, 2004 | 07:04 PM
ljnowell's Avatar
Thats what I was implying. THere is nothing about the car that requires it, so if the pump doesnt have it, cap it off.
Old Nov 17, 2004 | 05:30 PM
IROC_385Z's Avatar
Car: 88 Camaro IROC-Z
Engine: SBC 385
Transmission: 700 w/ manual valvebody & 2400 TCI
Axle/Gears: 9-bolt B&W w/ 3.70s
If your not using an EFI pump then you shouldn't need the return line. With my setup, for example, I chose to use the stock EFI pump with a return-regulator which still does need the return line...or else i'd have like 80psi up my carbs ***!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
