What company can I trust in to port AFR 190s?
Old Nov 11, 2004 | 05:23 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
So, who's great at porting heads.
Old Nov 11, 2004 | 06:08 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
How about AFR, they could probably CNC port them for you, if they still have a program for those heads.
Old Nov 11, 2004 | 08:59 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Well, I have thought of that. An email will find out the cost.
Old Nov 11, 2004 | 09:31 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Here is the place that I have talked to. It's called Total Engine Airflow. AFR wanted about $900 to CNC port my 195's. TEA wanted $800. Also, TEA can make them flow over 300 cfm where as AFR's CNC job will not.
http://www.totalengineairflow.com/
Old Nov 11, 2004 | 09:32 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
TPI$ might be worth a try too. They use AFRs on the engines they build.
Old Nov 11, 2004 | 10:00 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thanks for the tips, thats what I need.
I have also considered the company in PA. that did the Magnum TPI 395 cu.in engine build for GM Hi-Tech magazine.
I think TPIS is costly, but it doesn't hurt to email them.
Old Nov 11, 2004 | 10:19 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
When money permits, I'm most likely gonna go with these guys...
http://www.advancedinduction.com/
They're pretty popular with the LT1 crowd.
Old Nov 11, 2004 | 10:21 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Just an FYI... TEA just got bought out by Trick Flow. They are in the process of closing down in Bowling Green KY and moving to Akron OH to open up shop again.
They will continue their current business, and continue to port Ford and Chevy heads. TFS bought all their CNC programs for LS1 and LT1 heads, and they will be a part of TFS, but also be their own business if that makes sense. If you need anything done in a timely fashion, I wouldn't count on them right now. Let them get settled into their new shop and then call them...
Old Nov 12, 2004 | 07:08 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
It's kind of a mad house there right now lol. I do recomend them though. I've seen thier work and even helped do a few "heads and cam" jobs for them. Some of the stuff they do is amazing. Brent Lightfoot just finished tuning a LS1 Vette that made like 520rwhp and got 31mpg.
Old Nov 12, 2004 | 07:24 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
since your mentioned the LT1 crowd, Lloyd Elliot over on camaroz28.com does outstanding port work....there are guys over there withmore then 400RWHP running his head and cam packages (he also makes custom cams speciffically for his heads)...and also VERY VERY affordable...400 for his stage 1's which flow roughly 260 on sotck LT1 castings
Old Nov 12, 2004 | 09:15 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Yeah, LE does great work too from what I've seen...in fact I want to get one of his head/cam packages for a budget type build up on my wifes LT1.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ULTM8Z
Oct 2, 2015 01:25 PM
