Texas visual inspection, non.emmision
Old Nov 12, 2004 | 08:39 AM
contactpatch's Avatar
Engine: sbc 350
For Texans living in non.emmision counties,
does the inspector really require that the
air cleaner have that 'vacuum air door' thing?
Old Nov 12, 2004 | 09:01 AM
92lpeb4c's Avatar
Car: 1992 B4C
Engine: 4-bolt 350 219cam Superram
In South Texas I have never once had an inspector open the hood on my car. Most just check to see if your lights and breaks are working. I can be in and out of most inspection stations in about 5 minutes.
Old Nov 12, 2004 | 11:39 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
under hood visual inspection is required in all counties in Texas. that said some don't check, most do, all are required to check things such as brake fluid, horn mounting, power streeing fluid & belt if equipped, emission parts including the hot air door in the breather, the hot air tube, EGR valve, the charcoal canister & related vacuum hoses.
Lbibb
May 5, 2016 12:00 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
sylentnite
Sep 9, 2015 02:55 PM
