car wont start
Old Nov 12, 2004 | 07:35 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
car wont start
i ran out of gas and now the hog wont start.
im goin to pull the filter in a lil bit to c if fuel comes out the pump.. any other ideas?
Old Nov 12, 2004 | 09:42 PM
megaracerx's Avatar
i had the same thing happen to me...i put gas in it and it just wont fire...ergh pisses me off..
Old Nov 12, 2004 | 10:13 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Did you fry the fuel pump, if it is good you should hear it prime when you turn the ignition key on..
Old Nov 12, 2004 | 10:14 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Double post/....//
Old Nov 13, 2004 | 02:07 AM
sinner's Avatar
i checked the relay and it switches on when the key is on. i dont hear the pump now. i took the fuel filter off and turned on the key and nothin hapens.
so, this mean the pump is toast?
how do i replace it?
Old Nov 13, 2004 | 08:06 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Check for the pump to come on by applying 12 v to the G terminal of your aldl.
Old Nov 13, 2004 | 12:13 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Let us know if your pump is working or not.. What happens is that when you run out of gas the little motor inside the pump overheats and stops working as there is no more fuel to keep it cool. It happend to me so i learned from my mistake..
If it is the pump there is lots of info here on how to replce it..
Good luck.
Old Nov 13, 2004 | 12:18 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Maybe this will help you.. Do what Red Devil says..
Old Nov 13, 2004 | 12:53 PM
sinner's Avatar
i was looking through the archive and the tech area and i didnt see what i needed on how to replace the fuel pump. am i looking in the wrong place?
Old Nov 13, 2004 | 01:59 PM
sellmanb's Avatar
Car: '86 Berlinetta
https://www.thirdgen.org/techbb2/sho...cing+fuel+pump
that should do it for yah.
Old Nov 13, 2004 | 03:47 PM
sinner's Avatar
thanks for the help, when i searched i found nothing like that. i must be doing something wrong
Old Nov 17, 2004 | 08:59 PM
orod's Avatar
Car: 86 Z-28
Hey guys, I recently got my 86 z back from my brother so I haven't been on for about a year. It would seem I'm having the same prob. I too, do not hear my pump priming and have checked everything but the filter and the juice goimg to the pump. so just to be sure how do i test the pump? I'm trying to check every possibility before i rip the tank out.
Thanks,
O. Rod
Old Nov 17, 2004 | 09:49 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Old Nov 17, 2004 | 09:53 PM
orod's Avatar
Car: 86 Z-28
will check it out asap and get back to you. thanks
orod
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
