harmonic balancer is toastes
Old Nov 13, 2004 | 09:22 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
balancer is toasted guys, whats the cost of a decent repalcemtn and how do i install one?
Old Nov 13, 2004 | 09:57 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Do you know how to perform a search?
Who needs a balancer anyway?
Old Nov 13, 2004 | 10:15 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Prices range from about 40 bucks to 400, suggest a stock replacement will be fine for you.
Appropriate was is to use a puller/installer, import set is pretty cheap to buy, most DAP's will rent one to you too. If they don't have instruction with them, just repost...if you do it correctly you'll still have threads left in the crank, if you don't, then you'll be tapping oversize.
Not sure of clearance issues, may need to remove some things to get at it.
Old Nov 13, 2004 | 10:21 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
bought one for $50 5 minutes ago, droped it off at a shop and they are charging me $80. i have got to be at work at 12PM didn't have enought time todo it myself.
Old Nov 13, 2004 | 10:45 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's why I try to do everything myself...I just think of what tools I can buy for 80 bucks
Old Nov 13, 2004 | 10:46 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
yeah but i think of all the scrapes and bruises i'll have when i get done and goto work.Plus the amount of time yelling da*mn sh*t *ss motherf*cker at the darn car. This is my consideration.
Shane
Old Nov 13, 2004 | 02:01 PM
sellmanb's Avatar
Car: '86 Berlinetta
-scratches head- if you dropped it off at a shop then you didnt need to buy the puller. My suggestion.... clean off the tools after it gets done and return them. Think of it as "tool rental"
Old Nov 13, 2004 | 02:21 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
$80 is enough to get the damn tools. 20 minutes later I'd be drinking a beer.
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think he meant that he bought the balancer, not the tool.
Old Nov 13, 2004 | 02:28 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
J.C. Denton
Sep 21, 2015 04:23 PM
Magman
Sep 13, 2015 12:14 AM
