injectors aren't firing
Old Nov 14, 2004 | 03:58 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
i went to start my car a few minutes ago, and it wouldn't start. so i check for spark...good. then check for fuel..none. the injectors aren't firing, anyone know what the problem could be?
Old Nov 14, 2004 | 04:21 PM
ede's Avatar
ede
relay?
Old Nov 14, 2004 | 04:22 PM
JOHNCOO5's Avatar
Car: 85 IROC-Z
Engine: 5.0 TPI
You should probably check the fuses first then maybe search on the boards for your problem, there is lots of replies to that same problem in the last few days. I have the same problem but mine is in the wiring because I just changed the harness and not quite everything is worked out yet. If you find any good info, let me know.
Good luck,
Doug
Old Nov 14, 2004 | 10:37 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
well, i went to start about 20 minutes later and it started right. so i don't know what that was all about. but im thinkin since it happend once it will probable happen again.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
rsrookie
Sep 5, 2015 07:08 PM
