FLYWHEEL RESURFACING
Old May 31, 2001 | 03:20 PM
matty350TPI's Avatar
How do you know when it is time to get the flywheel resurfaced? Also how do you adjust the clutch, my clutch only grabs very near the top of the pedal travel. It doesn't slip, I checked with a 3rd gear low speed start by flooring it. HELP PLEASE.
Matt
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old May 31, 2001 | 05:02 PM
Ken88GTA's Avatar
Hi,
The only way to be sure is to visually inspect it for heat cracks, ridges, and hot spots. Depending on it's condition, you can either clean it up yourself or have it resurfaced at a shop. The high pedal probably indicates your pressure plate is weak, not sure if there are any adjustments to be made to the pedal/linkage that would help.
Good Luck
Ken
Old May 31, 2001 | 05:14 PM
COME ONE GUYS ANYONE KNOW HOW TO ADJUST THE LINAKGE?????
Old Jun 1, 2001 | 06:29 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
On hydrolic clutches you can't really adjust the linkage. It is your pressure plate that is weak and causing that condition. I have the same problem. My clutch catches when my foot is almost on the top.
As for indication of the flywheel, if your car vibrates when you start from first then you should have it resurficed, and also when you put on a new clutch.
Good luck.
Old Jun 1, 2001 | 07:50 AM
blak92!'s Avatar
you cannot adjust the a hydralic clutch. My clutch catches at the top also, which is normal. If you clutch is catching at the very bottom then you have problems.
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
Bubbajones_ya
Jul 6, 2024 08:32 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
