Top Dead Center, Lining up Distributor
Old Jun 1, 2001 | 05:21 PM
Kyle F's Avatar
OK, at top dead center both vlavels will be closed an the rotor will be lined up to the #1 spark plug wire. Now when you look at the harmonic Balancer will it be straight up? I don't think it has to be, but my brother and I are having problems getting power out of the new Motor. The harmonic balancer is about 30* past straight up to the drivers side.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 1, 2001 | 05:34 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That's about right. 30 deg clockwise while facing the motor from the front is about where it'll sit. Maybe more like 15-20 deg though. But yea that's right. Do you have a pointer or tab on the timing cover? That should give you a ball park range. Usually you want 12-14 deg. BTDC of timing when you first start the engine. Then go from there. I'm sure you will get better suggestions later though.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
sonu1975
Aug 11, 2015 08:38 AM
