long block 350 4 bolt
Old Nov 18, 2004 | 05:30 PM
82crossfire's Avatar
Car: 1982 chevy camaro
Engine: 305cfi
i have an entire 350 4 bolt main i recently aquired, all it needs is a rod bearing, what is this worth in the ball park? heads and all
Old Nov 18, 2004 | 05:31 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
$100
Old Nov 18, 2004 | 05:32 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
i would guess you would need to know how many miles are on certain parts in it how old it is whats inside of it and all
Old Nov 18, 2004 | 05:33 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
it may just need a rod bearing but you also have to have the crank checked for problems and if it had a bearing fail odds are it got shavings in the oil which in turns usually destroys the rest of the bearings too.....so id say 100 bucks would be fair
Old Nov 18, 2004 | 05:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You are basically buying a core. $100 sounds right.
Old Nov 18, 2004 | 06:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Can also take out the rod and crank. Been there, seen that.
Old Nov 18, 2004 | 07:07 PM
THEGENERAL's Avatar
Yup got a 305 out of my pickup that has that problem right now from a head gasket going out while going down the interstate...LOL..
makes a good boat achor now...
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
