MAF to Air cleaner
Old Nov 20, 2004 | 12:47 PM
1986T&A's Avatar
Car: 1986 Trans Am
MAF to Air cleaner
My connection between the maf and air cleaner is not a tight fit. It just kinda lays in there, I see an oring there, should that be a tight fit and what kind of problems could that give me?Yhanks.
Old Nov 20, 2004 | 03:28 PM
Vader's Avatar
I'm not sure what your car looks like, but a stock '86 TA MAF and air intake tube setup looks a lot like this:
Old Nov 20, 2004 | 03:32 PM
Vader's Avatar
There is a clamp at each end of the MAF semsor, and at the joint between the air duct and the air cleaner assembly.
Old Nov 20, 2004 | 04:08 PM
1986T&A's Avatar
Car: 1986 Trans Am
well my clamp is missing that is holding the elbow portion into the air filter ***. With a loose fittingthere could that cause this kind of problem. when I am going about 25 with no pressure on pedal the rpms will go from 100 to about 1300 or 1400 and then back to 1000? The ses light is on with a 33 code.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
