Screw in rocker arm studs
Old Jun 2, 2001 | 12:45 AM
NORT's Avatar
I have a set of L31 vortec heads, I,am wanting to install a set of screw in rocker arm studs. What I need to know is will the Summit brand or regular screw in studs work Ok in those heads. these are the type that you have to machine the boss. I hope they will work OK because I ordered a set. I had a guy tell me that those type won't work on some late model heads. I would really appreciate some feedback on this. Thanks NORT
Old Jun 2, 2001 | 07:17 AM
ede's Avatar
ede
no idea about summit studs, i prefer and use ARP screw in studs. 7/16x3/8 or 7/16x7/16. i mill .400 off the stud boss and the set the head up in my drill press to tap the holes. if you have SA rockers and/or don't use guide plates you'll have to knock the top few threads off ,i use a 7/16 drill in a tap wrench and a counter sink in a drill press,to accomodate the radius under the hex on the studs. i know jegs makes studs that require no machine work other than tapping the threads.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 3, 2001 | 06:51 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I used the simple 'no machining' screw in studs from jegs. Actually they are made by mr gasket and labeled as 'street screw in studs'...
All you need to do is tap the hole, put some sealer on the threads, double nut it and tighten 'em down. I have about 20,000 on them so far with no probs.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
