Ok, I got the numbers. What a PITA
Old Jun 3, 2001 | 06:57 PM
bhaas's Avatar
Here are the numbers from the back drivers side of the motor. 460776 and here's the ones from the pass side rear of motor. C297.
Hope this is it. Cause that's all the numbers there are. Had to pull the distributor. Oh what fun. Thanks. Newvermind. I found out what it is. Thanks for the help anyway.
Pad numbers. F0414 BorR A
Brad...
[This message has been edited by bhaas (edited June 03, 2001).]
Old Jun 3, 2001 | 07:05 PM
mrgto's Avatar
Where are the numbers from the pad on the passenger side front that I told you about? I need those numbers to tell what it is. The casting number is good, but kind of useless without the pad numbers.
Old Jun 3, 2001 | 07:08 PM
bhaas's Avatar
Old Jun 3, 2001 | 08:10 PM
jms's Avatar
jms
The 460776 number shows to be a 305 block from 1976-1979.
The C 29 7 number would then be March 29, 1977 as the casting date.
jms
Old Jun 3, 2001 | 08:26 PM
bhaas's Avatar
What about this number F0414 BorR A off of the front plate on the pass side. Thanks.
Old Jun 3, 2001 | 08:36 PM
jms's Avatar
jms
Those numbers correspond with the vin # of the car the engine came out of. There is a three letter code (1970 and later) that also (usually) tells what type of vehicle the engine originally came from but I don't have the letter codes from 1977.
jms
Old Jun 3, 2001 | 09:04 PM
bhaas's Avatar
Where did you get your info at for the cast numbers? Can you get the numbers from chevy or just somewhere on the net? Thanks.
Brad...
Old Jun 3, 2001 | 09:50 PM
jms's Avatar
jms
Over 30 years of hands-on experience and 3,000 magazines and books (I still have them all!)
jms
Old Jun 3, 2001 | 10:10 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Go to mortec.com
They have a lot of casting #s for reference, plus brief descriptions. I doubt that they have them all though.
It sounds like jms might have them all though.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Rousseau92maro
Feb 1, 2016 05:12 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
WECoyote
Aftermarket Product Review
35
Apr 21, 2002 09:41 PM
86TpiTransAm
Nov 17, 2001 12:50 PM
evilho7810
Aug 27, 2001 05:14 PM
