Hey need some info on heads please
Hey where can I find out what kind of heads the people said they were a set of 88 350 L98 heads I want to confirm that and I am going to have them redone so what is the best thing to do for them????
Go to www.mortec.com, they have GM head and block casting numbers listed at that site.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
or www.nastyz28.com
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.6 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker, certified engine and electrical systems mechanic
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
litemupp
Aug 23, 2015 10:09 PM
