So this is a common noise?
Old Nov 24, 2004 | 02:27 AM
Lampropeltis's Avatar
Car: '89 Flame red metallic GTA!!
I just installed an aftermarket air filter on my '89 L98 GTA. It is an open element filter w/ a heat shield that covers the rear half of it. Ever since I put this on, the car makes a very loud hissing noise at idle, like its madly sucking air in - which is what I am guessing is what is happening and that that is what that air filter is designed to do. Sorry for the dumb question, but this is my first performance car so I am new to some of the sounds that you are supposed to hear. Let me know if this sounds right.
Old Nov 24, 2004 | 02:28 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yup. Open filters do make more noise. As far as the hissing, I've never had a TPI so I don't know, but I wouldn't be too alarmed.
Old Nov 24, 2004 | 12:04 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
You think thats a bad thing??? Enjoy the noise!
Old Nov 24, 2004 | 02:48 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Yes, its normal.
Also so you're forewarned: I don't know how apparent this will be on yours because you have them MAF so you'll have some tubing too, but on my SD car, I had the K&N open that mounted to the TB, and when you open the throttle there was a very noticable pop.
Old Nov 24, 2004 | 04:16 PM
Actually I never thought it a bad thing ( I think it sounds pretty cool - like its a heavy breather and waiting to go), I just wasn't sure if it should be doing that or not.
goumba, thanks for the forewarning. I was interested in that air filter right off the throttle body, but from what I understand, thats difficult to do with the MAF system. I am happy with what is on there now, except I want to replace the rubber hoses with something solid and polished so I have to explore that. Thanks for the heads up though.
Peace
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
Royal_Z
Sep 30, 2015 08:45 PM
