Stealthram and vacuum lines
Old Nov 24, 2004 | 03:45 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Just finishing up the install of the HSR on my 1991 Z28 . Im down to the upper rad hose and vacuum lines. I bought this system used and looked at Holleys instructions as to what fittings are neede and where theay are tapped. Everything looks like it was done correctly. I have 4 fittings on the back of the plenum. 2 large and 2 small. 1 large for the brake booster, 1 large for the PCV valve to the valve cover. Great. 1 small for the AFPR and 1 small for the MAP sensor. Great.
PROBLEM:
Im left with 2 vacuum lines. 1 for the heater controls (vents) and 1 3 way valve thing the I believe has to do with cruise control. What do I do with them? Can I plumb the heater control to the 3 way valve and add a port? How do you guys do it? Maybe someon can make me a little diagram...
Kris
Old Nov 24, 2004 | 08:24 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
TTT
Please!
Old Nov 25, 2004 | 12:40 PM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
Transmission: 5 Speed
The heater control and cruise control vacuum line (if it is the one that goes to the cruise control vacuum storage canister) needs to have manifold vacuum, so you can T into any line you have there. That should take care of it.
Old Nov 25, 2004 | 12:46 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Thanks!!
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
