shift linkage cable help
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
About 3 weeks ago, the shift linkage cable broke, leaving me with the shifter that just slid, so we replaced it with one from autozone, identical cable, installed fine. Now, out of no where, it won't go into park, when i throw the shifter up all the way it goes in reverse. We took a look at it today and it almost seems like the cable is too short now, and won't reach. we took a hammer and banged on some bracket now if you play with it abit itll just barely get into park. I've tried searching, found a few posts about it but no one really said how they fixed it, or what they adjusted, etc, so I figured i'd throw it out there again, any help appreciated.
rob
rob
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: shift linkage cable help
rob
rob
Originally posted by Wesdog
pull up the console and check there. The cable has a rubber ring that mounts on the metal plate near the shifter. My tranny wouldnt shift into park and it was because the rubber had come out. I think you can also adjust the placement of the actual shifter which would adjust the shift cable position on the tranny. There should be a couple of bolts that you can loosen and move the shifter a little.
hit the
button and punch "adjust shifter cable" in the box and hit enter it brings up alot of threads about this problem Junior Member
Car: 1987 Camaro SC
Engine: LG4 305
Transmission: TH700R4
I replaced my shift cable about a month ago and it works fine. However, it was tricky to get the top end of the cable to clip into the metal bracket inside the shifter console. The first couple times I test shifted it before I re-assembled the console the outside of the cable would pop-out where it snaps into that bracket when I would shift gears going back into Park. I was finally able to get it snapped in securely and have no further problems. I thought maybe the same thing is happening for you because I experienced the same symptoms as you are having. The cable I bought would be the same exact part as you bought for your car. The part number for mine is CA 1110. I hope this helps.
Rob
Rob
I also purchased my new cable from autozone for my 87 Iroc
it done the same thing it kept jumping out of the bracket under the shifter plate. I returned it to autozone they gave me a refund
and said they have had a lot of problems with this model cable
went to GM purchased a new one not one problem since.
TheTraut88
Sep 7, 2015 05:22 PM
