low idle
Old Jun 5, 2001 | 07:18 PM
88transam5.0's Avatar
low idle
When my car is in drive (No A/C on) my idle is about 500-550. Now when I turn on the A/C in drive my idle now is @ 600-650. I've replaced the tps and adjusted to .56 and I also, replaced the IAC valve, throttle body is clean. any suggestions. thanks.
Old Jun 5, 2001 | 07:30 PM
Vader's Avatar
88,
Did you set the minimum throttle position according to the directions?
As part of the directions, you need to use a hand held tachometer to set the position. The dash mounted instruments are not reputed to be highly accurate (I'm trying to be NICE - they really suck except for the voltmeter).
Just some thoughts.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 5, 2001 | 08:04 PM
Vader, I used my autoxray which I hope is fairly accurate and I set the TPS @ .56 or should I just set it @ .54, In the past I've adjusted the minium idle but I was never sure if I did it correctly. I know while I was trying to adjust minimum idle the car would keep dying on me until I screwed in the idle screw about 1 1/2 turns from factory setting and this seemed too much but I may be wrong. please help.
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
Prodigious
Oct 4, 2015 11:20 PM
perZ
Aug 21, 2015 05:51 PM
perZ
Aug 15, 2015 01:17 PM
