couple questions reguarding tuning
Old Jun 5, 2001 | 10:31 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey guys, i'm having some problems, what would cause popping in the exhaust? it does it once and a while when it's idleing, also when i go to take off it kinda falls on its face sometimes poping through the carb but then it gets going, and it's fine, but if you keep a steady RPM it surges, sometimes when i open the 4bbl it bogs down and pops through the carb, question is, am i running lean on the 4bbl? look at my sig for the mods, it's the stock q-jet carb, also it's burning a lot of oil when you open it up and downshift, only in 2 cylinders though, which i dont think it's my rings, and the heads are new.
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
MustangBeater20
Oct 29, 2022 09:20 PM
Cleotiz
Jan 6, 2018 08:56 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
