Power Steering Pump Installation
Old Nov 30, 2004 | 04:33 PM
NoCal91Convert's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 Speed
I can't seem to get the rebuilt power steering pump to line up on my 91 Iroc Z. Seems the seams on the resevoire hit the aluminum mounting bracked. Any help out there?
Old Dec 1, 2004 | 04:45 AM
ede's Avatar
ede
if it hits grind the bracket fro clearance. i'll bet you don't have something installed or lined up right, if you have the correct parts.
Old Dec 1, 2004 | 09:04 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
maybe it's a "special edition" iroc z, since they were no longer produced after 1990...
but what he said... might have to grind a little, but theoretically shouldn't have to - should be a direct replacement. but one never knows. i just had to grind down the are on my plenum over the fuel press reg when i replaced it with an afpr that is supposedly made for tpi, so... go figure.
Old Dec 1, 2004 | 10:34 PM
It sure looked like a direct replacement, but once I turned the core in it was impossible to tell. I am going to visit a few service locations tomorrow and see if there are any small differences in some of the rebuilt pumps.
Thanks for your help.
Old Dec 2, 2004 | 01:48 PM
OK, if any of you are still interested.... I found the answer! Seems the pumps are the same, but the orientation of the reservoir is a bit different. I just picked up one that is about 30 degrees additionaly clockwise. With the tight fit in the serpentine belt set-up that difference means the wrong oriented reservoir will NOT fit. I have yet to try installing this new one, but it looks to be the answer.
PS, I got the correct one at Auto Zone, but Kragen did take back the one I got from them AND refunded the full amount plus core charge. No questions, no fuss.... gotta respect that.
Ken
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
