can you make a timing mark? some timing and gear questions
Old Dec 2, 2004 | 01:11 AM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
hey guys i recently put my 87 formula on the road due to lack of another functional car.." i say this loosly" ok i swaped my old thin harmonic balancer that would vibrate the car alot, and put on a balancer from a 85 TA with a tired 305 4bbl. my timing marks do not line up. can you put a timing mark where it needs to be?if so how? also my car originally had a 305 4bbl with auto 4 spd. and i swapped to pre 76' 350 and a 4 speed.. i think my car has something like 2.80 gears in the rear but seems like whenever i try to get rollin in 1st i get a octane ping..? also my car will start up great in the cold and will fire up quickly within the first 5 minutes of shutting it off but if i wait 10 minutes or more it takes a good minute to get her to barely catch idle and bring itself back to life...i was thinking when the car is hot the fuel evaporates and it takes a while to pump it in again? sound crazy...?also my first gear seems really huge and i know 4 spds. arent the top choice but what gears should i be the happiest with for fast street use..anyone know any good chevy shops in nj central nj..someone to tune my motor to perfection...thanks alot guys. i trust this site more than any mechanic
Old Dec 2, 2004 | 04:40 AM
ede's Avatar
ede
timing tape, if you don't know where the mark needs to be you'd have to find TDC befroe you use the tape. guess you could make a mark with a piece of chalk, soap stone, or paint.
Old Dec 2, 2004 | 11:18 AM
drex's Avatar
ok i can find top dead center....what next.? find tdc and mark top of balancer???
Old Dec 2, 2004 | 11:37 AM
ede's Avatar
ede
you have a timing tab on your timing cover right? make a mark on your balancer to match the zero mark on the timing tab.
Old Dec 2, 2004 | 03:00 PM
drex's Avatar
excellent thanks ede
midge54
Dec 27, 2019 04:14 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
Thirim
Aug 9, 2015 06:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
