Questions about stock 350 heads
Old Jun 6, 2001 | 12:16 PM
R.O.B.'s Avatar
What is the casting number for the stock 350 heads, isn't 882?
Does anyone have flow numbers on this?
Would a stock 350 head make a good performance upgrade for a 305, provided its milled down to 58cc of cource.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Jun 6, 2001 | 01:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 882 is one of a large number of stock 350 castings, specifically a common 350 and 400 head from the 70s.
In as-cast form, it's a terrible head. Hogged out as much as you can, it's still a mediocre one at best. For a 305, it would be a very bad choice; it has 76cc chambers, so the compression ratio on a 305 with flat-tops would be less than 8:1. I don't think you could mill enough off of one of those to bring the CR back up even to 9:1.
So no, it would not make a good performance upgrade for a 305, or for anything else for that matter. It's a downgrade any way you slice it for almost any motor.
ICON Motorsports
MustangBeater20
Oct 29, 2022 09:20 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
