are these good heads for my motor???
Old Nov 30, 2004 | 09:42 PM
86interceptor's Avatar
Car: 86 Z-28 Police Interceptor
Engine: 305 but building a 350
Transmission: 700r4 with shift kit
I have a 30 400 sbc with flat top pistons and 10:1 compression, I have a rpm air gap intake, a crane 224/234 duration at .050 with 465/488 lift and 114 lsa. I have a 750dp holley, a th350 trans and 2600 stall. will these heads be a good addition to my motor? http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Old Nov 30, 2004 | 10:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd look for something with a bigger runner and bigger vavles, to take advantage of the 400cid's.
How about these: http://www.webpages.uidaho.edu/~osie4078/proheads.htm
Old Nov 30, 2004 | 10:25 PM
I would love to have those heads but I can't afford them, the heads on ebay are only like 280 dollars.
Old Nov 30, 2004 | 10:27 PM
Chris`s85Z28's Avatar
Car: 1985 Z28
Engine: LG4 305 with a few modds
Well I looked at the pic and read the specs and it dosen1t match up, it says there 72CC chambers well in the pic they look ahell of lot smaller then 72cc they look more like 62cc, they look smaller then my 64 CC bowtie heads, and the specs say 1.94 intakes and those look like 2.02`s to me and it also said they flow 210 cfm`s at .500" well one of the worst small block Chevy heads the 882`s flow like 200 or 205 CFM`s and the L98`s flow 199 so there flow kinda sucks, so if it was me I`d stay away from them. and your cams LSA is to big, carbs like 110 not 114 your LSA is more for a F.I engine, if I was you I`d look into a cam, and stick with the heads you have unless you have the 882`s they`re just junk, everything else looks good in your combo I`d just go with a bigger cam with a tighter LSA but don`t go below 110
Old Nov 30, 2004 | 10:29 PM
my heads are worse then the 882's they are 997's lol and I had thought very seriously about a bigger cam.
Old Nov 30, 2004 | 10:41 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
The Dart SS heads are stock replacement heads, pass on them. 165 cc runners, 1.94/1.50" valves 72cc chambers.
Stock, stock, stock, or close.
http://www.dartheads.com/csbhiron.htm
Old Nov 30, 2004 | 10:44 PM
I am beginning to see that now, I am new to reading flow charts on heads, thats why I ask you guys all these anoying questions all the time
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
NinjaNife
Aug 23, 2015 11:49 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
