big trouble in little tokyo
Old Dec 3, 2004 | 02:30 PM
bitch'ncamaro's Avatar
Car: 80 z28
ok my car will not start, it will crank but will not start. the last time my car was in runnig order was about a week ago, the day before it quit i retarded the timming to 8* witch is spec. it ran fine the next day then it snowed and my car would not start. choke is in runing order. i gave the distributer some play while cranked and nothing so i thew timming as my problem out. i checked and my roter is spining while crank (i was keeping my battery charged in another car between all this cranking) there is no spark geting to the plug side of the plug wires(witch i replaced 3-4 months ago) so do you think it could be my rotor, ignition modual, or coil
thanks for the help
Old Dec 3, 2004 | 02:52 PM
ede's Avatar
ede
yeah that'd be my guess as to your problem, among few other related parts
Old Dec 3, 2004 | 03:48 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
coil would be my guess.
Old Dec 3, 2004 | 05:21 PM
Car: 80 z28
ok so i replaced the roter, and the igniton mod, but still nothing. i fell like the coil is not making good contact with the roter (the coil sits right on top on my 80) so im low on $$$ and need to know
coil, or new cap?
Old Dec 3, 2004 | 05:57 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Clean the contacts on both first and see if it gets you anywhere. It might not even be either.
Old Dec 3, 2004 | 06:15 PM
Car: 80 z28
i cleaned all of my contact points and nothing
on a side note my optima ownes
Old Dec 3, 2004 | 06:56 PM
Car: 80 z28
im going to go to the yard and pull a coil (if i can find one) in the morrning but if there is any thing else i can do/look out for please tell me, thanks again every one
Old Dec 4, 2004 | 11:47 AM
Car: 80 z28
brand new coil and NOTHING! im going to charge my battery than try some more but someone please help!
Old Dec 4, 2004 | 01:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
try the pickup coil which is located in the shaft of the distributer. Not the Coil, not the Ignition module, its the pickup coil.
Old Dec 4, 2004 | 02:05 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
how about instead of replacing every part it MIGHT be you buy a cheap multimeter for $10 at radio shack and test the parts and the connections FIRST??????
Old Dec 4, 2004 | 03:59 PM
Car: 80 z28
haha.. yeah i returned the mod and got my $$ back, in a last ditch effort i towed it up to like 25-30mph and put it in gear she fired up and i dialed the timming and now its seem to be fine thanks everyone for the help
Old Dec 5, 2004 | 01:20 AM
Morley's Avatar
Well that makes no sense...it would crank over but not start...but when you "push" started it...it started up....You may have wiring issues.
Old Dec 5, 2004 | 11:48 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Um Yea
Old Dec 5, 2004 | 12:23 PM
/\/3\/\/l8l3's Avatar
Check the Flux Capacitor, and next time you tow, remember 88 mph
Old Dec 7, 2004 | 11:41 AM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
make sure the 12 volt wire to the distributor is in good condition and connected.
Old Dec 7, 2004 | 12:19 PM
Car: 80 z28
its been a few days and my car seems fine it must be something that the cold had triggerd but i dont think that the new coil hurt. i will check out for a wire problem agian thanks!
p.s. i dont understand what happend ether.
Old Dec 7, 2004 | 10:59 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
Your muffler bearings probably just needed a little lubrication.
Push starting is a good way to loosen them up.
I have to do it to mine about once a year.
Old Dec 8, 2004 | 12:14 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
never heard of such a thing...?
Old Dec 8, 2004 | 07:44 PM
sellmanb's Avatar
Car: '86 Berlinetta
Mighta been low blinker fluid too, you can have a hard time turning on the car if your blinker fluid is too low, and you can burn them out too
J/K man... I'm glad you got your car fixed... I would have never thought of "push" starting the car like that.
Old Dec 8, 2004 | 08:23 PM
Car: 80 z28
lol thanks everyone hahaha
mrbird
Oct 20, 2015 03:43 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
Lmancha96
Sep 25, 2015 08:11 PM
