Plumbing advice
Old Dec 4, 2004 | 01:18 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Plumbing advice
I just received my Vortec Edel. RPM Air Gap Manifold. Here’s the picture with it mocked on the engine. I need help in plumbing it up. I remember seeing a post or website that had posted instruction on how the person plumed his setup but I can’t seem to locate it.
Old Dec 5, 2004 | 11:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure if this is what you meant...
https://www.thirdgen.org/techbb2/sho...hreadid=269407
Old Dec 6, 2004 | 10:02 PM
86z/92rs's Avatar
Thanks you for the link, I needed to know how I should plumb water ports on my setup.
Old Dec 7, 2004 | 04:40 AM
ede's Avatar
ede
same as the factory set up? is there a reason you'd not want it like it was?
Old Dec 7, 2004 | 03:30 PM
86z/92rs's Avatar
Just wondering if I should use all the water ports or just use the ones that the 305 stock tbi came with.
ZZ3Astro
Aug 13, 2019 12:57 AM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
