AFR springs and Max lift..
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I replied via email, so you can take a look for that.
Yup, thje 987 springs are a 1.43" OD so they will fit. Since you are running alum heads, spring cups or locators of sort might be something to consider.
I would just match the retainers to the springs. Comp sells 10° retainers that are a perfect fit for their 98x series of springs. You would be able to reuse the locks then.
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I don't know about the standard springs but with my AFR's I have the spring upgrade for .600 lift. Also, I've had no problems with mine. They are over a year old.
355tpipickup
Sep 13, 2015 11:35 PM
