need help
If it's a very very slight amount you can clean it off with a "bottle brush hone" chucked in a drill. I've also used an old, rough, terry cloth towel sprayed down with penetrating oil and LOTS of elbow grease. If it's heavier than that you need to get a shop to hone it out again.
Oh, yes. If it's not too bad then it can definitely be done. I've done it myself several times on engines that had gotten a little surface rust in the bores from sitting a while (usually in my damp basement) before assembly.
