Losing oil pressure?
Old Jun 7, 2001 | 09:31 AM
Hulk0202's Avatar
I have a 91FB 305TBI w/146000 miles. My oil pressure starts off at about 30-35 psi when idling, and will rise slightly with acceleration. After driving for a while and bringing the car to operating temp. my pressure dips to 20-25 and will reach 30 under acceleration. Oil is changed regularly. Is my pump going? Maybe a pressure test would help. Any ideas?
Old Jun 7, 2001 | 10:40 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
What you are experiencing is normal wear on the bearings and such. Pressure will decrease over time. So long as you keep up on the maintenance, you should be fine. GM says anything over 10psi at idle is ok.
Time to start collecting money for a rebuild though.
Old Jun 7, 2001 | 11:48 AM
sleeper's Avatar
Of course your oil pressure drops once the car heats up. Once the oil gets warm it thins out a bit thus decreasing pressure.
What happens to the Crisco when you heat it up in the frying pan?
There's nothing wrong with your engine. Like ploegi says... wait until it's under 10psi... then your bearings are failing.
1986 Trans Am
carbed 350 - .30 over with 9.75:1 comp.
+- 315hp/390ft lbs.
700-R4 with 2500 stall
3.27 (ick!) gear
SLP 1 3/4" headers w/MAC catback and cat.
96 5 stars
SFC's, braces, arms, and a bunch more expensive stuff
no timeslips yet
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
