Maf Problem
Old Dec 6, 2004 | 09:11 PM
new442's Avatar
Maf Problem
My 89 L98 shows a 33 code. When I use the factory trouble shooting proceedure, there is no problem found. I replaced the maf sensor with a known good one and still get a code 33. I monitored the maf pin on the ecm with a vom and it stays at
5 volts even when I raise the rpm from idle to 3000rpm. The wire
from the maf sensor output to the computer is continous (.2 ohm). Does this point to a a problem in the ecm? The engine runs and idles well.
chazman
Aug 28, 2018 03:25 PM
GTAman
Sep 21, 2015 09:57 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
