307 - 305 cam
Old Dec 9, 2004 | 12:56 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
307 - 305 cam
Hey guys
got a question for y'all, whats the difference between a cam from a 307 and one from a 305. The reason im asking is because my brother just gave me a cam from his 307. It's in pretty good shape and i was thinking of using it in my 305.
Ive got a hunch that chevy used the same cam in these two engines but im not 100% sure- so i thought id ask u guys...
thanks
Old Dec 9, 2004 | 01:16 PM
ljnowell's Avatar
Not a lot of difference, they will both suck. With how cheap a flat tappet cam is (whats in the 307) there is no way in hell that I would bother with re-using an old one.
Old Dec 9, 2004 | 03:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I don't think I would re-use a flat tappet cam period. Especially if the lifters weren't matched or do not come with the cam.
Old Dec 9, 2004 | 04:35 PM
oh ok. well this is my first time rebuilding an engine and I kinda figured it would be a good way to save a little money. Also its only a 305 so its not like im building a high performance racer or anything.
so if i did use an old cam in it, are you guys saying that my rebuilt engine would not last long? or run really pourly?
Old Dec 9, 2004 | 04:46 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The story is that using an old cam with old lifters that were not originally used with that cam will cause rapid lobe wear.
The lifters and the lobes kind of "learn" each other and the wear pattern matches one of the other.
It is said that swapping a used cam from one engine to another is OK if the lifters are matched to the lobes they were on originally. I think it's a wive's tale. No two engines are alike anyway. A slight difference in alignment of the lifter bores from one engine to another could be enough to wipe a lobe.
For ~$80 you can get a cam and lifter kit from www.SummitRacing.com
Old Dec 9, 2004 | 05:48 PM
nsimmons's Avatar
summit cams are good. Im using one, ive used 2 before. Nothing spectacular, but hey its 80 bucks
Jake_92RS
Jan 28, 2020 10:37 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
