BUILD A TTA 3.8 V6 TURBO
Old Jun 7, 2001 | 08:00 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
well im very interested into swap my old 2.8 carb from my 82 firebird s/e and i was thinkin of a V8 but ive been hearing so good comments about the turbo 3.8v6 ..what will happen if i put on a turbo 3.8 from a Regal or a Grand national???will it perform like the 89TTA closely...will it be better than a V8 ? it will work with my TH 200C tranny???
Old Jun 8, 2001 | 03:58 AM
86ZRICHIE's Avatar
well, the V8's wil probably have more performance parts available than the relatively new 3.8's, but aside from that, I only really have one more thing to add since I dont' know if the tranny will work...
My uncle has an old vette with a 350 pullin around 300HP and a new supercharged Regal, and he swears the Regal is quicker off the line, but the vette would beat it hands down on the top end.
[This message has been edited by 86ZRICHIE (edited June 08, 2001).]
Old Jun 8, 2001 | 07:30 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I doubt the 2.8 would hold together, and if some chance it did, the tranny would either kiss the floorboard or the asphalt.
The 2.8's weakest point (besides cubes) is the crank. The compression is low enough for forced induction, but I wouldn't thrust the stock parts for too much. As for power, a big turbo on the smaller motor would cause it to spool up later (lag) and really shine going toward the upper end (5,000-5,500) where it would just scatter....
The heads would choke everthing off...
Disregard this post if you were thinking of replacing the 2.8 with the 3.8, I may have mis-understood...
Old Jun 8, 2001 | 07:33 AM
JoelOl75's Avatar
You did say put the turbo "on" did you?
You'd have to loose the carb (reminessant of the 301 turbo firebird 17 second mistake) and go with FI before the above post becomes relevant.
Turbos don't like carbs. Turbos don't like alot of things...
Disregard this if.....
Old Jun 8, 2001 | 12:13 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i'm gonna be doing this swap myself in a few months....i looked long and hard the performance u can get out of these engines with minimal mods....i know people that are running high 11's and still getting over 20 MPG(on a stock turbo 3.8 bottom end) nice isn't it? I doubt your tranny will work...don't quote me though....best thing to do is get the entire drivetrain from a GN or T-Type....best thing to do is go to either www.turbobuick.com or www.turbobuicks.com or www.gnttype.org Talk to people over there...they will help u with this project if u are truely serious....
Good luck....let us know what u decide
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Jun 8, 2001 | 10:04 PM
Killer-Z's Avatar
Tony...still tryin to scrape enough beans together, eh? Derrick
Old Jun 9, 2001 | 07:56 PM
fly89gta's Avatar
Car: 2018 Camaro SS
<font face="Verdana, Arial" size="2">Originally posted by Killer-Z:
</font>
YOOOOOOO man...yeah...this layoff is killing me...the project probably won't be done till late winter/early next spring its ok though...i'm patient...i'll tweak the 350 a little more...then make way for the TTA motor
ZZ3Astro
Aug 13, 2019 12:57 AM
86White_T/A305
Sep 21, 2015 05:28 PM
R13_Braz
Sep 18, 2015 05:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
