high speed vibration
Old Jun 12, 2001 | 10:14 AM
PAformula's Avatar
My car developed a vibration at any speed over 65 mph. I had all the tires re-balanced and last night I tightened the front right wheel bearing. Everything else is tight. I had an alignment done last fall.
What else should I check for?
1989 FIREBIRD FORMULA 350
K&N, ACCEL CAP & ROTOR,
FLOWMASTER AMERICAN THUNDER CAT-BACK
Old Jun 12, 2001 | 03:38 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Check/replace your U-joint. If that's not the problem then you need to replace your driveshaft.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
